no spanning-tree optimize bpdu transmission
jgates
What does this command do exactly?
ajagadee
The command "no spanning-tree optimize bpdu transmission" is a hidden command and
basically used for debugging.
This command is related to a cosmetic bug which should not have impact on your network. This bug is purely cosmetic and there
should be no reason for concern.
Below is the BUG ID:
CSCee70806.
Arul
*Pls rate if it helps*
