No Storm-Control unicast level
rwamstutz
All, I am enabling this command on a port, but when I do a show storm-control <port> unicast, the output doesnt show any information.
I do have the NIC that connects to the server disabled right now, can this be why?
I don't understand, storm-control is disabled by default. Remove the commmand I suggested under the port config and it will be disabled.
8 Replies 8
Edison Ortiz
sh run int f0/2
Building configuration...
Current configuration : 120 bytes
interface FastEthernet0/2
storm-control unicast level bps 25k
spanning-tree portfast
show storm-control fastEthernet 0/2 unicast
Interface Filter State Upper Lower Current
Fa0/2 Link Down 25k bps 25k bps 0 bps
What type of switch are we dealing here ?
Can you post the port config ?
its a 3750. Here is the config. I can enter the command, but the command does not show in the config:
Current configuration : 171 bytes
interface GigabitEthernet4/0/15
description ServerA
switchport access vlan 201
switchport mode access
flowcontrol receive desired
end
Interesting, my ouput was from a 3750.
Remove the flowcontrol and copy and paste my storm-control command.
Post back with results.
Current configuration : 209 bytes
interface GigabitEthernet4/0/14
switchport access vlan 200
end
Gi4/0/14 Forwarding 25k bps 25k bps 0 bps
It's showing up now, what was the syntax before ?
I am wanting it disabled on this port, not enabled.
tonypearce1
Level 3
Level 3
To the OP is this in relation to a Equalogic SAN document that tells us that we must disable this feature which is enabled by default? I searched Google and found this page.
Thank you,
