12-11-2014 09:03 AM - edited 03-07-2019 09:51 PM
Hi everyone,
I'm facing a strange problem, on a 4500x VSS cluster, when I type the track command in global config mode in order to track some object the switch doesn't seem to recognise the command.
VSSCLUSTER(config)#track
% Invalid input detected at '^' marker.
Litterature says it is well being implemented :
But I'm on 03.05.00.E and 15.0(1r)SG10. Does it mean I need to upgrade to get the functionnality? Thank you
Below the show version:
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.05.00.E RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 27-Aug-13 14:56 by prod_rel_team
Cisco IOS-XE software, Copyright (c) 2005-2013 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: 15.0(1r)SG10
VSSCLUST uptime is 29weeks, 5 days, 18 hours, 59 minutes
Uptime for this control processor is 1 week, 3 days, 8 hours, 38 minutes
System returned to ROM by SSO Switchover
System restarted at 09:17:01 cet Mon Dec 1 2014
Running default software
Jawa Revision 2, Winter Revision 0x0.0x41
Last reload reason: power-on
License Information for 'WS-C4500X-16'
License Level: ipbase Type: Permanent
Next reboot license Level: ipbase
cisco WS-C4500X-16 (MPC8572) processor (revision 9) with 4194304K bytes of physical memory.
MPC8572 CPU at 1.5GHz, Cisco Catalyst 4500X
Last reset from PowerUp
12 Virtual Ethernet interfaces
32 Ten Gigabit Ethernet interfaces
12-23-2014 10:36 AM
Command not implemented in that version:
https://tools.cisco.com/bugsearch/bug/CSCuj74457/?reffering_site=dumpcr
Workaround == downgrade or upgrade
