Nominal fiber SFP optical receive power
johnlloyd_13
Level 9
Level 9
hi all,
we got a 3650 switch that goes up/down from time to time.
the config it's just normal trunking.
i suspect it could be an issue with the fiber SFP.
could someone advise what's the nominal value for optical receive power?
anything else to look at?
#sh run int Gig 1/0/4
Building configuration...
Current configuration : 164 bytes
interface GigabitEthernet1/0/4
 switchport mode trunk
 switchport nonegotiate
end
#sh int g1/0/4 transceiver detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Gi1/0/4     30.7                90.0        85.0        -6.0      -11.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Gi1/0/4    3.34                  3.60        3.49        3.09       3.00
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Gi1/0/4     -5.9                 0.0        -3.0        -9.5      -13.5
           Receive Power      Threshold   Threshold  Threshold  Threshold
Gi1/0/4    -10.1                 1.0         0.0       -17.0      -21.0      <<< 3750X TO FLAPPING 3650
#sh int g1/0/5 transceiver detail
Gi1/0/5     32.4                90.0        85.0        -6.0      -11.0
Gi1/0/5    3.34                  3.60        3.49        3.09       3.00
Gi1/0/5     -3.8                 0.0        -3.0        -9.5      -13.5
Gi1/0/5     -4.8                 1.0         0.0       -17.0      -21.0    <<< TO ANOTHER WORKING 3650
Leo Laohoo
Post the output to the command "sh interface <BLAH>" of both sides.
