None License Switch
Hi, I'm currently looking for a cisco switch that doesn't need a license? can someone be kind enough to label some models for me thanks. The Switches will be used for hosting game servers non profit
If you just need layer-2 functionality with 1Gig copper interface, than you can purchase a Cisco 3560 24 or 48 port with IP Base license. Here is more info:
http://www.cisco.com/c/en/us/products/collateral/switches/catalyst-3650-series-switches/data_sheet_c78-729449.html
7 Replies 7
Reza Sharifi
Hi, what port density switch do you need?
Do you need 1Gig, 10Gig?
Do you need copper switches or fiber?
What protocols are you going to use?
Thanks for replying, I'm looking for something under or around 1GB with layer 2 STP
Thanks for quick reply.
For the 3548, you don't need any license but remember this switch is end of life and end end of support and very old.  Also, they are 10/100 and not Gig ports.
If you are looking for used switches on ebay, you are better off with Cisco 3750G switch.
have a look:
http://www.ebay.com/itm/Cisco-Catalyst-3750G-Series-WS-C3750G-24T-S-Switch-/201381719083
Again if you buy it on ebay, there is no support.
BTW, with 3750G, no need for license
oh 1 more question i bought a 2X CISCO CATALYST WS-C3548-XL-EN do i need a license for this? or is this just standard ip license
