stacking 3750-X and 3750G
steinie
What are the software features on 3750G and 3750-X are needed for the two models to be joined in a stack ?
Marvin Rhoads
Per Cisco (reference), "The Cisco StackWise technology requires that all units in the stack run the same release of Cisco IOS Software."
You can mix feature sets (i.e. IP Base vs. IP Services) but it's not generally recommended.
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
In addition to what Marvin has already noted, I recall you cannot use the LAN Lite IOS on the 3750-X and if the 3750G is a -12S, it need to use a compatible SDM template.
I later read that Lan Base feature set on 3750X only accepts stacking with other 3750X. In order to have 3750X stacked with other types (3750G etc) a Ip Base or IP Services feature set is needed.
This discussion has been reposted from Additional Communities to the LAN, Switching and Routing community.
