Noobie: bpduguard: connect Netgear Wifi Router
I am a total Cisco Noobie here, so don't be too hard on me.
I have a Catalyst 2960. It's completely vanilla other than portfast bpduguard set to default.
Now, I want to connect my Netgear AC3200 Wifi Router as an AP. I was previously using it in this fashion with my Linksys Unmanged Switch.
I connected the Netgear and of course the interface went to errdisable because of bpduguard...
So, how do I get around this? I understand the issue to be with STP and the connection of another switch, but where do I go from here?
DCook@slco.org
BPDUguard puts a port in err-disable state when it receives a bpdu on access port. Typically when I am connecting a router to a switch I configure the port as a trunk port...
first default the interface (config t , default interface gig XXX) then depending on the switch ( interface gig XXX, switchport , switchport mode trunk , description UPLINK-NETGEAR ,)
your interface would look something like this.
interface TenGigabitEthernet1/1/1
The Wifi Router wouldn't be used as a router, however strictly as a AP for the LAN. The router is actually a PfSense box.
Hello @JeremyRangel02166 ,
you need to disable BPU guard on the specific port where you connect the WIFI netgear device
int gi0/12
desc NETGEAR
spanning-tree bpdu guard disable
The command should be this one.
Hope to help
Giuseppe
yes you can just disable it
config t
interface xxxx
no spanning-tree bpduguard
