Not able to access switch via console
Hardus
Hello everyone,,,
I have 2960 switch and i can't access it using my console cable .
I can access other switches in my network ( 3560 & 2960 ) but i can't access only this switch.
may be the console port in the switch damaged? or it's a bug ?? !!! although the switch is worked normally.
luis_cordova
Hi @Hardus
Query: Do you have connectivity via telnet or SSH?
If you verify that there are no erroneous configurations in the console line, then it is possible that your console port is damaged.
