Not able to define qos type queuing on Nexus 1000V
Alberto Falconi
Hello does someone knows why I get this error on my Nexus 1000V version 4.2(1)SV2(1.1a) ?
switch-01(config)# class-map type queuing pippo
ERROR: Command (id: 2) not supported
should I enabe queuing somewhere ?
Thank you in advance ...
acampbell
Alberto,
Canyou try your command again but like these:-
class-map type queuing match-any pippo
or
class-map type queuing match-all pippo
Alex.
Please rate useful posts.
Regards, Alex. Please rate useful posts.
As before ... same problem ..
switch-01(config)# class-map type queuing match-any pippo
match-all   match-any
switch-01(config)# class-map type queuing match-all pippo
switch-01(config)#
Alberto,
According to the QOS config guide for your version :-
http://www.cisco.com/en/US/docs/switches/datacenter/nexus1000/sw/4_2_1_s_v_2_1_1/qos/configuration/guide/b_Quality_of_Service_Configuration_Guide_Release_4_2_1SV2_1_1_chapter_0110.html#concept_1C3B684C62BA46498A2D335F88DE3236
The olny item I can see that may be stopping the command is :-
Queuing is only supported on ESX or ESXi 4.1.0 or later hosts.
If you are meeting the criteria I think you should raise a TAC -- I could not find any bug for this
Alex.
Strange because ESXi is VMware ESXi 5.1.0 Releasebuild-1117900 (3.1)
nobody else got this error ?
