Not able to ping from vrf
CiscoNB2013
i have made a vrf on a router, in the vrf i have the layer 3 interface to the pe and a vlan interface for connecting a interface not routed to a switch.
The switch is configurerd with vlan interface 1 , 1 layer 2 interface in vlan 1 is connected to de ce.
I have put te routes on ce in the vrf but i' am not able to ping from the vrf to the vlan interface of te switch, why is this.
If y use a layer3 interface on the switch directly connected to the layer2 to interface of the ce i can ping from te vrf to the layer 3 interface of th switch
could any one tell me why this is.
Thank you verry much.
Glenn
Marwanshawi thx for your reaction, i included te config. I left some routes en config of other interfaces away because this is off the company.
I can ping from th vrf. ping vrf DMZ 172.18.1.254, i get a good replay, this is when the ip address 172.18.1.254 is configured on a routed interface of mine multy layer switch. I cannot ping form the vrf on the ce router to 172.18.1.254 when y delete the routed interface on the multy layer sw en make a interface vlan 1 with ip 172.18.1.254 with a layer 2 interface in vlan 1 that y connect to the interface on the router.
do you have some suggestions,
Regards Glenn
Marwan ALshawi
Do you use ping vrf vrfname ip
Can you post the config here to check it for you
