I am not able to ping gateway's on my firewall from 1 subnet to another. What can be the issue ?
Some details abotu existing network as follows :-
ASA0
Config:- VLAN config done as vlan1, vlan2 on ASA , acl etc done, nating is done >> 3COM L3 switch is next to ASA where those vlan's are terminated in separate ports, trunk port is their
vlan1 gateway = 192.168.1.1
vlan2 gateway= 10.100.10.1
ASA1
Config:- VLAN configured as above >> http traffic goes from this firewall >> No other config >> Cisco L3 switch is conencted & trunk is created to route traffic
vlan1 gateway = 192.168.1.45
vlan2 gateway = 10.100.10.45
What config shall I modify and where to enable ping to gateway's on ASA0 which are my primary gateways & assigned for all desktops?
