Not able to Ping
meict2010
I have two directly connected routers:
R1 <--Gi 0/2 --------- Gi 0/2 --> R2
R1:
hostname R1
vrf definition blue
 rd 3005:20
 route-target export 3005:20
 route-target import 3005:1
 route-target import 3005:10
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
vrf definition red
 rd 3005:10
 route-target export 3005:10
 route-target import 3005:20
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
vrf definition shared
 description SHARED VRF
 rd 3005:1
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
interface GigabitEthernet0/1
 vrf forwarding shared
 ip address 10.4.6.6 255.255.255.0
 ipv6 address 2000::10:4:6:6/112
 ospfv3 1 ipv4 area 0
 ospfv3 1 ipv6 area 0
interface GigabitEthernet0/2
 no ip address
interface GigabitEthernet0/2.10
 description VRF red
 encapsulation dot1Q 10
 vrf forwarding red
 ip address 10.6.11.1 255.255.255.128
 ipv6 address 2000::10:6:11:1/113
 ospfv3 1 ipv6 area 54
 ospfv3 1 ipv4 area 54
interface GigabitEthernet0/2.20
 description VRF blue
 encapsulation dot1Q 20
 vrf forwarding blue
 ip address 10.6.11.129 255.255.255.128
 ipv6 address 2000::10:6:11:8001/113
router ospfv3 1
 router-id 6.6.6.6
 address-family ipv4 unicast vrf shared
  redistribute bgp 3005
 exit-address-family
 address-family ipv6 unicast vrf shared
 exit-address-family
 address-family ipv4 unicast vrf red
  default-information originate always
 exit-address-family
 address-family ipv6 unicast vrf red
 exit-address-family
 address-family ipv4 unicast vrf blue
 exit-address-family
 address-family ipv6 unicast vrf blue
 exit-address-family
router bgp 3005
 bgp router-id 6.6.6.6
 bgp log-neighbor-changes
 no bgp default ipv4-unicast
 address-family ipv4 vrf blue
  redistribute ospfv3 1
 exit-address-family
 address-family ipv6 vrf blue
  network 2000::10:6:11:8000/113
 exit-address-family
 address-family ipv4 vrf red
 exit-address-family
 address-family ipv6 vrf red
  network 2000::10:6:11:0/113
 exit-address-family
 address-family ipv4 vrf shared
 exit-address-family
 address-family ipv6 vrf shared
  network 2000::10:4:6:0/112
 exit-address-family
R2:
hostname R2
vrf definition blue
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
vrf definition red
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
 ip address 10.10.11.11 255.255.255.0
 ipv6 address 2000::10:10:11:11/112
 no ip address
 vrf forwarding red
 ip address 10.6.11.2 255.255.255.128
 ipv6 address 2000::10:6:11:2/113
 vrf forwarding blue
 ip address 10.6.11.130 255.255.255.128
 ipv6 address 2000::10:6:11:8002/113
router ospfv3 1
 exit-address-family
 exit-address-family
 exit-address-family
 exit-address-family
I did the following pings:
R2>ping  vrf red 10.6.11.130
Sending 5, 100-byte ICMP Echos to 10.6.11.130, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 3/3/4 ms
R2>ping  vrf red 2000::10:6:11:8002
Sending 5, 100-byte ICMP Echos to 2000::10:6:11:8002, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/2/3 ms
R2>ping  vrf red 10.6.11.129
Sending 5, 100-byte ICMP Echos to 10.6.11.129, timeout is 2 seconds:
R2>ping  vrf red 2000::10:6:11:8001
Sending 5, 100-byte ICMP Echos to 2000::10:6:11:8001, timeout is 2 seconds:
Success rate is 0 percent (0/5)
What is wrong with the last Ping?
Thanks in advance,
Best regards
Richard Burts
The address that you are trying to ping is in vrf blue but your ping is trying to access it in vrf red.
Rick
Rick
That is true, I want to do Inter-VRF-Routing on Router R1.
All 4 Pings are Pings from Router R2 (vrf red) to vrf blue on both Routers.
With IPv4 everything works fine, the IPv6 Ping from
R2 (red) --> R1 (red) --> R1 (blue) --> R2 (blue)
works fine too, the only Problem is the IPv6 Ping from
IPv4 works fine for the same ping source/ destination Interface.
The Routing Tables
R1/  IPv4
R1>show  ip route vrf *
Routing Table: blue
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 6 subnets, 3 masks
B        10.4.6.0/24 is directly connected, 23:43:36, GigabitEthernet0/1
L        10.4.6.6/32 is directly connected, GigabitEthernet0/1
B        10.6.11.0/25 is directly connected, 23:17:01, GigabitEthernet0/2.10
L        10.6.11.1/32 is directly connected, GigabitEthernet0/2.10
C        10.6.11.128/25 is directly connected, GigabitEthernet0/2.20
L        10.6.11.129/32 is directly connected, GigabitEthernet0/2.20
Routing Table: red
C        10.6.11.0/25 is directly connected, GigabitEthernet0/2.10
B        10.6.11.128/25 is directly connected, 23:43:36, GigabitEthernet0/2.20
Routing Table: shared
C        10.4.6.0/24 is directly connected, GigabitEthernet0/1
R1/ IPv6
R1>show ipv6 route vrf *
Routing Table: blue
B   2000::10:4:6:0/112 [20/0]
     via GigabitEthernet0/1%shared, directly connected
B   2000::10:6:11:0/113 [20/0]
     via GigabitEthernet0/2.10%red, directly connected
C   2000::10:6:11:8000/113 [0/0]
     via GigabitEthernet0/2.20, directly connected
L   2000::10:6:11:8001/128 [0/0]
     via GigabitEthernet0/2.20, receive
L   FF00::/8 [0/0]
     via Null0, receive
Routing Table: red
C   2000::10:6:11:0/113 [0/0]
     via GigabitEthernet0/2.10, directly connected
L   2000::10:6:11:1/128 [0/0]
     via GigabitEthernet0/2.10, receive
B   2000::10:6:11:8000/113 [20/0]
     via GigabitEthernet0/2.20%blue, directly connected
L   FF00::/8 [0/0]
     via Null0, receive
C   2000::10:4:6:0/112 [0/0]
     via GigabitEthernet0/1, directly connected
L   2000::10:4:6:6/128 [0/0]
     via GigabitEthernet0/1, receive
L   FF00::/8 [0/0]
     via Null0, receive
