Not able to reach over VRF lite
Sanjib Pradhan
Dear Friend,
I have configured VRF on R1.
ip vrf R2
rd 11:11
ip vrf R3
rd 22:22
ip vrf R4
rd 33:33
Interface Configuration:
interface FastEthernet0/0
ip vrf forwarding R2
ip address 12.1.1.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip vrf forwarding R3
duplex auto
speed auto
interface FastEthernet1/0
ip vrf forwarding R4
duplex auto
speed auto
interface FastEthernet2/0
ip address 15.1.1.1 255.255.255.0
duplex auto
speed auto
PROBLEM:
I am not able to ping 15.1.1.1 from  R2 , R3, R4 as they have already a Default Route towards R1.
R2#ping 15.1.1.1
Sending 5, 100-byte ICMP Echos to 15.1.1.1, timeout is 2 seconds:
UUUUU
Success rate is 0 percent (0/5)
Route on R2:
S*   0.0.0.0/0 [1/0] via 12.1.1.1
Is there anything that I have missed here????
Sanjib
2 Accepted Solutions
Bilal Nawaz
This is because VRF is a totally separate routing table that is specified to the VRF. Since you assigned the interface to the VRF you will only have connectivity to the connected router.
You assigned R1 fa0/0 to a separate VRF (VRF R2) only the attached interface will have access to this VRF.
You would perhaps need to do route leaking on R1 between VRF's.
Try 'show ip route vrf R2' etc... you may see there arent any routes to the 15.1.1.1 network. You will only see connected.
Think of it as connected to another router. The router's within R1 (VRF's) need to be able to talk to each other to achieve your goal.
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
Hello
Bilal is correct even though this is just one router its has acting separate routers becasue of vrf. is enabled.
Try this on R1.
This puts routes in the global table towards the vrf nexthops
ip route 12.1.1.2 255.255.255.255 FastEthernet0/0
ip route 12.1.1.3 255.255.255.255 FastEthernet 0/1
ip route 12.1.1.4 255.255.255.255 FastEthernet1/0
This tell the vrfs how to get to R5 via the global table
ip route vrf R2 15.1.1.0 255.255.255.0 15.1.1.5 global
ip route vrf R3 15.1.1.0 255.255.255.0 15.1.1.5 global
ip route vrf R4 15.1.1.0 255.255.255.0 15.1.1.5 global
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Bilal Nawaz
Dear Bilal,
Thanks..
To achive my objective then how to configure the device so that R2 can able to ping 15.1.1.1. Please explain in details.
Hello
Try this on R1.
res
Paul
Thanks.
Kind Regards
Paul
