02-16-2016 10:04 AM - edited 03-08-2019 04:36 AM
Configured static IP -
AP5c83.8f45.90ec#sh capwap ip config
LWAPP Static IP Configuration
IP Address 10.28.104.49
IP netmask 255.255.255.240
Primary Controller 10.6.120.5
AP5c83.8f45.90ec#ping 10.6.120.5
Sending 5, 100-byte ICMP Echos to 10.6.120.5, timeout is 2 seconds:
Success rate is 80 percent (4/5), round-trip min/avg/max = 24/40/72 ms
AP5c83.8f45.90ec#
Error on AP console ....
Mar 1 00:02:44.083: %CAPWAP-3-STATIC_TO_DHCP_IP: Could not discover WLC using static IP. Forcing AP to use DHCP.
Not in Bound state.
*Mar 1 00:03:44.091: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Rene wing DHCP IP.
Not in Bound state.
*Mar 1 00:04:34.091: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Rene wing DHCP IP.
AP5c83.8f45.90ec#
Not in Bound state.
*Mar 1 00:05:24.091: %CAPWAP-3-DHCP_RENEW: Could not discover WLC. Either IP address is not assigned or assigned IP is wrong. Rene wing DHCP IP.
AP5c83.8f45.90ec#
AP5c83.8f45.90ec#sh cap ip con
Automatically reboot AP
Writing out the event log to flash:/event.log ...
ip co
Write of event.log done
n
*Mar 1 00:05:34.135: %SYS-5-RELOAD: Reload requested by CAPWAP CLIENT. Reload Reason: Could not discover WLC using DHCP IP address , Reload to use static IP.
*Mar 1 00:05:34.135: %LWAPP-5-CHANGED: CAPWAP changed state to DOWN
IOS Bootloader - Starting system.
flash is writable
Antigua Board
40MB format
Tide XL MB - 40MB of flash
Xmodem file system is available.
flashfs[0]: 14 files, 2 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 41158656
flashfs[0]: Bytes used: 6179840
flashfs[0]: Bytes available: 34978816
flashfs[0]: flashfs fsck took 10 seconds.
Base Ethernet MAC address: 5c:83:8f:45:90:ec
Ethernet speed is 1000 Mb - FULL Duplex
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx"...#########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-mx" uncompressed and installed, entry point: 0x2003000
executing...
Secondary Bootloader - Starting system.
Antigua Board Pre-Pilot
40MB format
flashfs[1]: 0 files, 1 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 12257280
flashfs[1]: Bytes used: 1024
flashfs[1]: Bytes available: 12256256
flashfs[1]: flashfs fsck took 0 seconds.
Boot CMD: 'boot flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx;flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx'
Loading "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx"...########################
File "flash:/ap3g2-rcvk9w8-mx/ap3g2-rcvk9w8-xx" uncompressed and installed, entry point: 0x1003000
executing...
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, C2700 Software (AP3G2-RCVK9W8-M), Version 15.3(3)JA3, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2015 by Cisco Systems, Inc.
Compiled Thu 19-Feb-15 10:27 by prod_rel_team
40MB format
Initializing flashfs...
flashfs[2]: 14 files, 2 directories
flashfs[2]: 0 orphaned files, 0 orphaned directories
flashfs[2]: Total bytes: 40900608
flashfs[2]: Bytes used: 6179328
flashfs[2]: Bytes available: 34721280
flashfs[2]: flashfs fsck took 11 seconds.
flashfs[2]: Initialization complete.
flashfs[3]: 0 files, 1 directories
flashfs[3]: 0 orphaned files, 0 orphaned directories
flashfs[3]: Total bytes: 11999232
flashfs[3]: Bytes used: 1024
flashfs[3]: Bytes available: 11998208
flashfs[3]: flashfs fsck took 0 seconds.
flashfs[3]: Initialization complete....done Initializing flashfs.
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-CAP2702I-E-K9 (PowerPC) processor (revision A0) with 376810K/134656K bytes of memory.
Processor board ID FCW1933NNRD
PowerPC CPU at 800Mhz, revision number 0x2151
Last reset from power-on
LWAPP image version 8.0.115.0
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 5C:83:8F:45:90:EC
Part Number : 73-15824-03
PCA Assembly Number : 000-00000-00
PCA Revision Number :
PCB Serial Number : FOC193221KY
Top Assembly Part Number : 068-100379-01
Top Assembly Serial Number : FCW1933NNRD
Top Revision Number : A0
Product/Model Number : AIR-CAP2702I-E-K9
% Please define a domain-name first.
Translating "CISCO-CAPWAP-CONTROLLER"...domain server (255.255.255.255)
Press RETURN to get started!
*Mar 1 00:00:13.007: APAVC: Initial WLAN Buffers Given to System is 2500
*Mar 1 00:00:13.059: APAVC: WlanPAKs 42878 RadioPaks 42270
*Mar 1 00:00:13.059: Starting Ethernet promiscuous mode
*Mar 1 00:00:13.063: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:15.063: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:15.063: %LINK-6-UPDOWN: Interface GigabitEthernet1, changed state to up
*Mar 1 00:00:15.203: %SYS-5-RESTART: System restarted --
*Mar 1 00:00:16.231: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
*Mar 1 00:00:19.811: DPAA Initialization Complete
*Mar 1 00:00:19.811: %SYS-3-HARIKARI: Process DPAA INIT top-level routine exited
*Mar 1 00:00:20.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0, changed state to up
*Mar 1 00:00:22.811: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar 1 00:00:23.811: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
ipv6 enable
% Invalid input detected at '^' marker.
ipv6 address autoconfig
ipv6 address dhcp
*Mar 1 00:00:24.247: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar 1 00:00:24.395: %SSH-5-ENABLED: SSH 2.0 has been enabled
*Mar 1 00:00:27.235: %LINK-6-UPDOWN: Interface BVI1, changed state to up
*Mar 1 00:00:28.235: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
bridge-group 1 source-learning
*Mar 1 00:00:34.059: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar 1 00:00:37.435: %CDP_PD-4-POWER_OK: Full power - NEGOTIATED inline power source
*Mar 1 00:00:39.435: %LINK-5-CHANGED: Interface GigabitEthernet1, changed state to administratively down
WLC configuration
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.130.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 1.0.0
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... UKMKCSWP00002
System Location..................................
System Contact...................................
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.6.120.5
Last Reset....................................... Software reset
System Up Time................................... 459 days 7 hrs 16 mins 30 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... Multiple Countries:BE,FR,GB,IT,NL
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +24 C
External Temperature............................. +28 C
Fan Status....................................... 3700 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Enabled
Number of WLANs.................................. 4
Number of Active Clients......................... 0
Burned-in MAC Address............................
Maximum number of APs supported.................. 75
02-17-2016 04:35 AM
I've noticed that there are different software versions on your AP (8.0.115.0) and WLC (7.6.130.0). So there may be incompability between them and I suggest you to upgrade your WLC code or downgrade your AP code. Here is compability matrix - http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html
Also there maybe some firewall between your WLC and AP. Or some MTU mismatch...
Have you tried to connect AP directly to WLC port?
Here is great troublethooting guide - http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/119286-lap-notjoin-wlc-tshoot.html
