Not capturing Span traffic on WS-4510/SupervisorV/12.2(54)SG1 - Need suggestions
p.ferreira
I have configured Span port on our 4510.
We have an application 5view server to monitor trafic connected to G9/17
Since we have changed the network connection from physical Giga port and add a Port-channel instead, we don't see any more trafic from the new Port-channel to G9/17
We have the configuration below on our 4510 :
monitor session 1 source interface Gi4/6
monitor session 1 source interface Po20
monitor session 1 filter vlan 311 - 312 , 375
monitor session 1 destination interface Gi9/17
From the commands show, we don't see the trafic duplication from the source to the destination port :
Port Source
4510-5567#sh int po20
Port-channel20 is up, line protocol is up (connected)
  Hardware is EtherChannel, address is 0016.9de2.a818 (bia 0016.9de2.a818)
  Description: XXXXX
  MTU 1500 bytes, BW 3000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is N/A
  input flow-control is on, output flow-control is unsupported
  Members in this channel: Gi3/3 Gi7/3 Gi8/6
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  30 second input rate 407000 bits/sec, 138 packets/sec
  30 second output rate 1448000 bits/sec, 528 packets/sec
     2743611133 packets input, 3198552879690 bytes, 0 no buffer
     Received 1898931 broadcasts (1898929 multicasts)
     3024889888 packets output, 557953005488 bytes, 0 underruns
     0 lost carrier, 0 no carrier
port destination
4510-5567#sh int g9/17
GigabitEthernet9/17 is up, line protocol is down (monitoring)
  Hardware is Gigabit Ethernet Port, address is 0008.e37a.b522 (bia 0008.e37a.b522)
  Description: YYYYYYY
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s, link type is auto, media type is 1000BaseT
  input flow-control is off, output flow-control is off
  Last input 17:26:10, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 110407
  30 second input rate 0 bits/sec, 0 packets/sec
  30 second output rate 5000 bits/sec, 9 packets/sec
     8129016 packets input, 543506527 bytes, 0 no buffer
     Received 6898978 broadcasts (6898972 multicasts)
     0 input errors, 0 CRC, 0 frame, 29 overrun, 0 ignored
     10481458187 packets output, 7456714191492 bytes, 0 underruns
. Does anyone have any suggestions ?
I have attached the show monitor session and show version
Best regards
Try this:
no monitor session 1
monitor session 1 source interface Gi4/6,Po20 both
monitor session 1 destination interface Gi9/17 encapsulation dot1q
monitor session 1 filter vlan 311-312,375
Hope this helps....
Hi, thanks for your response. I'm trying the new monitor configuration. I get back to you asap.
