not enough power for both camera and pan tilt motors sg-300 10p
Oguz
ı am using sg-300 10 p poe switch for 3 fixed and 2 ptz axis cameras. But ı am getting not enough power for both camera and pan tilt motors  any solution there?
the most you can do is set the ports to class 4 power (30.0 Watt), have a look at page 222 of the attached user guide:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/Cisco_300Sx_v1_4_AG.pdf
For sg-300 these setting arent aviable . I cant change class as 4 . And ı cant set power . It is really tertibble . Have you expirince before same isssu?
check the power requirement of Camera. if it is not matched by switch, you need to use matching power injector or matching switch
regard,
Good luck
KB
Alan Ng'ethe
Level 3
Level 3
I have faced this problem in the past, and resolved it by running lldp.
In global config mode;
lldp run
Remember to rate helpful posts and/or mark as a solution if your issue is resolved.
