not expected ospf behavior
bassem.selmi.ext1
Community Member
an interface is well configured to be considered in an ospf process by the network statement.
TenGigabitEthernet8/3.3276 is up, line protocol is up
Internet address is 10.203.55.50/30
Broadcast address is 255.255.255.255
router ospf 395 vrf OAM
network 10.203.55.0 0.0.0.255 area 0
However, the process isn't running on the interface as seen below:
sh ip ospf 395 interface Te8/3.3276
%OSPF: OSPF not enabled on TenGigabitEthernet8/3.3276
What can be the reason and how can be solved?
Rolf Fischer
Level 11
Level 11
does sub-interface Te8/3.3276 belong to VRF OAM?
In order to check some basic state information, could you share the output of
  • show ip vrf OAM
  • show ip vrf interface OAM
  • show ip protocol vrf OAM
Rolf
