Not possible anymore to copy/paste a preencrypted (Type 9) user/secret
Hi guys,
i´m a bit confused, what worked like a charm for many many years seems not to work for me anymore, actually the first time.
I put in a username/secret like follows:
username blabla privilege 15 secret <Cleartextpassword>
Afterwards i take the line from the running config
username blabla privilege 15 secret 9 fsfsfunnyhashedpasswordnln3452
and try to copy it to another routers config, which always worked for me.
Today: I end up in a line
% Incomplete command.
Or, when i use to generate that line which i want to copy using
username blabla privilege 15 algorithm-type scrypt secret <Cleartextpassword>
after pasting (the encrypted config line) to another router with THAT message:
ERROR: The secret you entered is not a valid encrypted secret.
To enter an UNENCRYPTED secret, do not specify type 9 encryption.
When you properly enter an UNENCRYPTED secret, it will be encrypted.
I´m aware of the concept of hashes and salts, but should it really be not possible anymore to generate such user/secret-lines on one Cisco box next to you for the colleagues and paste these handful of lines to other Cisco-devices? We cannot have an AAA-server for this purpose, some of these customers don´t even have more than a PC behind the routers. So, simply a local personalized login for us staff is the weapon of choice.
Does anybody know a workaround for this problem?
BTW:
I tried on various switches with 15.x and Cisco-routers ISR4k with IOS-XE 16.x and 17.x ...everywhere the same game.
Thanks in advance for any input!
Kind regards,
Andreas
stsagalas
I had the same problem until i realize that the encrypted SCRYPT hash uses $ sign as a separator and if  "shell processing full" command exists then this creates an issue as $ sign is also used as a place-holder for variables.
Remove the command "shell processing full" and copy/paste of SCRYPT hash works as expected.
7 Replies 7
thomas
I suggest moving your question to a IOS switch or router forum, not ISE, since this is clearly an IOS CLI-specific question.
Many thanks, Thomas, my fault when creating that post in sort of a hurry
 There are many similar posts here. It seems Cisco change some security policy related to it. And if we think it through, it make sense. Be able to replicate a password between device is a security risk.
I agree to you and completely understand that concern, but not being able to simply copy and paste a preencrypted/hashed line with a secret is also not too helpful in certain cases.
Just think about it, i would have to let a certain colleague whcih should help us in monitoring, troubleshooting, or simply a new teammember which needs access on a device locally (without sing AAA, radius or whatever, because sometimes routers and switches are deployed in a very small environment) on all the devices PER device.
This is a bit overcomplicated, instead of having a set of config lines as a (let´s say) default when configuring a new device or simply add it via script runs with ansible.
So, i am still searching a solution for this.
Not sure if it will do the trick, didn´t try jet, but maybe i do the same on a old device (md5) and while pasting it on a new device it gets automatically "leveled up" as type 9
Let´s see
stsagalas
Thanks, i‘ll try it!
Thanks, you nailed it. This was my problem. And actually it makes sense, even there could be some hint from IOS
