Notification when Uplinks go down
ricky-li
Whats the easiest way for me to get notifications when the uplinks on my 3560-24T's shutdown/disconnect from each other? Also can the same idea/steps be applied to 3550-12Gs?
I tried turning on logging in the Cisco Network Assistant but I ended up getting notified on every single port status change like when a computer gets rebooted.
You should be able to disable link status traps on access ports with the interface command 'no logging event link-status. This should filter all the unwanted traps.
SW1-3550(config)#logging trap 5
SW1-3550(config)#int range f0/1 - 23
SW1-3550(config-if-range)#no logging event ?
bundle-status BUNDLE/UNBUNDLE messages
link-status UPDOWN and CHANGE messages
spanning-tree Spanning-tree Interface events
trunk-status TRUNK status messages
SW1-3550(config-if-range)#no logging event link-status
SW1-3550(config-if-range)#int f0/24
SW1-3550(config-if)#logging event link-status
SW1-3550(config-if)#do show run int f0/24
Building configuration...
Current configuration : 119 bytes
interface FastEthernet0/24
switchport mode trunk
switchport nonegotiate
SW1-3550(config-if)#do show run int f0/23
Current configuration : 99 bytes
interface FastEthernet0/23
switchport mode dynamic desirable
Sundar
6 Replies 6
royalblues
Level 10
Level 10
Unfortunately all the link up/down status are sent as level 3 syslog messages or errors. This will include both the access as well as your trunk ports between the switches
I dont think there is any specific MIB either for you to get this information to a network management station.
Narayan
Sundar
no logging event link-status will filter out syslog messages, but not SNMP traps. To disable SNMP link traps for certain interfaces, you also need the following under each interface:
no snmp trap link-status
ricky-li
Thanks everyone, the SNMP traps actually worked easier than the syslogs because I'm using intermapper the traps got sent out automatically once they were received.
its' working too great, does anyone know what this means all the switches are generating these messages at some random interval:
05/25 11:12:45: Message from InterMapper 4.5.5
Event: TRAP
Document: 1164-C1-switches
Address: 10.10.21.13
Probe Type: SNMP MIB-II (port 161 SNMPv1)
Condition: SNMPv2-SMI::enterprises.9.0.1 (v2c) {
SNMPv2-SMI::enterprises.9.2.9.3.1.1.1.1 : "5",
TCP-MIB::tcpConnState.10.181.69.64.23.10.8.29.128.55297 : "5",
SNMPv2-SMI::enterprises.9.2.6.1.1.5.10.181.69.64.23.10.8.29.128.55297 :
"78624", SNMPv2-SMI::enterprises.9.2.6.1.1.1.10.181.69.64.23.10.8.29.128.55297
: "729", SNMPv2-SMI::enterprises.9.2.6.1.1.2.10.181.69.64.23.10.8.29.128.55297
: "17219", SNMPv2-SMI::enterprises.9.2.9.2.1.18.1 : "" }
Time since last reported down: N/A
Device's up time: 27 days, 21 hours, 4 minutes, 4 seconds
This is a tcpConnectionClose trap. It indicates a TCP (most likely a telnet) session has closed. You can disable these traps by removing the "tty" keyword from your trap config.
