NTP Authentication on Cisco Nexus 7000
sreelalggbm
I am configuring NTP on a new Cisco Nexus 7000 running version 6.1(2).
NTP is working properly between the access switches and Nexus, however when configuring Authentication, NTP is not working anymore.
confguration:
Nexus 7K server
ntp server x.x.x.x
ntp peer q.q.q.q
ntp server e.e.e.e
ntp server r.r.r.r
ntp source-interface  Vlanx
ntp authenticate
ntp authentication-key 1 md5 cisco
ntp logging
ntp master 12
Client 4500
ntp authenticate
ntp trusted-key 1
ntp source Vlanxx
ntp server x.x.x.x key 1 prefer
ntp server c.c.c.c key 1
Please advise why NTP authentication is not working !!!!! on Nexus 7000
Reza Sharifi
On the 7k, can you also add this command:
ntp distribute
and test again?
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_2/nx-os/system_management/configuration/guide/sm_3ntp.html
Do we need to add this in Admin VDC or the VDC where we are working?
The NTP distribute is needed when you are using CFS Distribution for NTP.
however NTP is working as per sreelalggbm however when authentication is not working.
