NTP auto disconnect every week (sunday)
posemman
May I ask if you encountered auto disconnect to NTP server?
Our cisco C2960-LANBASEK9-M always disconnect every Sunday, our temporary solution is to reboot it. After reboot it will back to normal connection, and the NTP synchronized.
6 Replies 6
what device is 172.27.1.9 ?
Hi Georg,
It's our monitoring server. Linux based.
Leo Laohoo
Sounds like an IOS bug to me. What IOS version is the switch running on?
Is this the only switch having this problem? How about others (running different IOS version)?
It is Version 15.0(2)SE4. Yes this is the only switch having a problem.
5 other cisco switches were connected to this switch.
I've used 15.0(2)SE4 for years. Very, very stable. I have never seen an issue with NTP like this.
How are the downstream switches configured? Are they all pointing to the Linux server for NTP synch?
All downstream switches also point to 172.27.1.9 Linux server. Maybe the switch is old enough?
