NTP issue
sateeshk10
I have configured the NTP in my network. while i issued the follwoing command its showing 127 pool address..
it suppose to show the NTP server address which i given in my switch right..
Core#sh ntp status
Clock is synchronized, stratum 8, reference is 127.127.7.1
nominal freq is 250.0000 Hz, actual freq is 250.0000 Hz, precision is 2**18 reference time is CCF6449B.32D6EBCE (10:04:43.198 CST Fri Dec 19 2008) clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.02 msec, peer dispersion is 0.02 msec
sateesh kumar.k
ajagadee
Sateesh,
This is used as the localhost address (i.e. the router is using its own clock for synchronization). The below URL should help
http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_tech_note09186a008015bb3a.shtml
Arul
*Pls rate all helpful posts*
Thanks for immdiate response..
My questions is y its is showing local host as a NTP as i have given NTP server address?
ntp server 1.1.1.1.
Its suppose to show 1.1.1.1 in NTP status right..
sateesh
I find that frequently the presence of the 127 address in NTP is because the device is configured with the command ntp master. Have you configured ntp master on this device? If so I suggest that you remove ntp master and see if it then associates with the 1.1.1.1 that you have configured.
Rick
Rick
