NTP (VRF) problem
dan_wiebell
Level 2
Level 2
Having a problem with NTP on an 1841 with VRFs. I have configured the following:
interface VlanX
description NTP interface
ip vrf forwarding NTP
ip address <ip address>
ntp authentication-key 1 md5 blahblah
ntp authenticate
ntp source VlanX
ntp master 2
ntp max-associations 2
ntp server vrf NTP <public address 1>
ntp server vrf NTP <public address 2>
ip route vrf NTP <public address 1>
ip route vrf NTP <public address 2>
ip route vrf NTP <internal address 1>
ip route vrf NTP <internal address 2>
There is only one gateway via VlanX (the firewall).
NTP requests to the two ntp servers go out (confirmed in debug), but I get no hits on the firewall, permit or deny or otherwise. If I execute a ping from my router in the NTP vrf I get the appropriate hit.
However, if I configure another ntp server command pointing to an internal host:
ntp server vrf NTP <internal address 1>
I get the appropriate hit on the firewall. Ideas on how I can troubleshoot this? I've checked the bug tracker and there is no software bug listed for this model/image/ntp -
c1841-advipservicesk9-mz.123-11.YZ2
Reza Sharifi
Do you have s static route for the vrf
ip route vrf NTP x.x.x.x 255.255.255.255 x.x.x.x (vlan x)
As I posted above:
"ip route vrf NTP
ip route vrf NTP
ip route vrf NTP
ip route vrf NTP "
Routes are fine - as I said I can ping the addresses and generate the correct entries on the firewall.
NWT
Frequent Visitor
Frequent Visitor
It's been a while, but did you manage to solve the issue?
It seems we have the same thing happening where our router doesn't send the ntp traffic with the vrf, it uses the general interface instead which is why the asa doesn't know any routes for it.
Kr
Which device is in question?
Some devices do not support vrf aware ntp
IOS XE Release 3SE (3850/3650)
The switch does not support VRF-aware services
for Unicast Reverse Path Forwarding (uRPF) or Network Time protocol(NTP).
