Null0 Static route tracking using IP SLA and Track
rushabhsha
1. There is an edge router called router-A whose upstream OSPF neighbor is the firewall via an L-2 connection (switch). There is a VLAN running between the firewall interface and router-A
2. On router -A I have 4 null0 static routes to originate and advertise networks out of bgp to service provider
3. If the VLAN disappears from the OSPF routing table I want the Null0 to be pulled out as a result I wont be able to advertise the summary network statements via bgp
What I did:
1. Created a track to "track ip route-VLAN"
2. Associated the track with the static routes of null0
Question:
When I do show track, I see Reachability is up and connected but when I see tracked by: Static IP routing the number is 0
Is there anything I am missing ?
The output looks correct to me. You may want to test during a maintenance window if this is in production.
5 Replies 5
Reza Sharifi
What is the output of "sh track interface"?
Does it show null0?
I think for static ip routing it is always 0
STATIC-IP-ROUTING 0
My show track output says the following
Track4
IP route 10.x.x.x y.y.y.y reachability
Reachability is up (connected)
1 change, last change 00:35:02
First-hop interface is gig0/0/1
Tracked by:
Static IP routing 0
Sounds good.
Thank you
