Number of L2TP connection simultaneously on Router 1905?
Natha340Mai340
Hi all, I'm initializing a project with VPN L2TP on Router Cisco 1905. I'm purchasing the 1905 because cost efficient but I need provider up to 500 connection simultaneously L2TP and I can't find if 1905 provider up to 500 connection simultaneously....anybody has this information ??
thank!
I couldn't find anything for the 1900 series. Maybe Cisco need to upate their docs with the latest models.
I found this, but again, it's not the 1905 I'm afraid.
http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6549/ps6587/prod_white_paper0900aecd8066d3f5.html
IAN WHITMORE
Level 4
Level 4
I don't think it will. The tunnels use memory so memory will be an issue. I also think on the 1905 it is license based.
I found this but I don't think it's specific to your model:
http://www.cisco.com/en/US/docs/routers/access/sw_activation/SA_on_ISR.html
Table 7 is the interesting one that states maximum tunnels are 225.
To be sure though you should contact Cisco or your Cisco provider.
HTH,
Ian
Thank you IAN!
it's good your information about memory.because there is licence based for memory on 1905.
but the information about simultaneously Connections l2tp nothing!
if anybody has any tip please shared.....
thank
after some search stress I found something more near that I've need.
In an FAQ there is the follow question:
Q. Does the IOS Software packaging change on the existing ISR 1800, ISR 2800 and ISR 3800 product families?
A. The software packaging on the ISR 1800, ISR 2800 and ISR 3800 product families will remain unchanged and will not adopt the licensing, packaging and universal image concept outlined for the ISR G2 family.
I understand that 1905 is able up to 500 L2TP connections simultaneous because the 1800 was able that.
unfortunately my project was reproved because I haven't had time deliver the information to my costumer.
Thank IAN.
