Number of OSPF areas?
dajekels1
Happy New Year to all who may read my post :)
We have multiple L2 VLAN's on our 6509's and I am tasked to setup dynamic OSPF routing.
Which is better; cpu, memory and effective configuration.
1) create a OSPF area for each VLAN
2) create 1 OSPF area with all the VLAN's in it
off course our core are will be 0.0.0.0 which will span to all inter office router's connection points.
any advise/reading material on the subject would be greatly appreciated.
Jon Marshall
It is highly unlikely that you would want a separate area per vlan on your 6500 switch. That would make your configuration very complex.
If you have multiple offices one common setup is to have HQ as area 0 and your remote sites in different areas but without knowing more about your topology it is difficult to be more specific about what is good for you.
Attached is a link to Cisco white paper on OSFP design, have a read and them come back if you require further assistance.
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094e9e.shtml
Jon
Jon,
Thank you for the quick response, I have read this doc a few times and all the example configs in this guide only has 1 network assigned to an area.
Short of a lab; I just needed some clarification on the approach which I had stuck in my head :-)
Donny
