number of TCP connections
jlearmonth
Sorry if this is a stupid question, but how can I tell the number of active TCP connections that say a switch or router is currently handling? I've tried looking at tcpActiveOpens.0 and tcpPassiveOpens.0 in the MIB, but they don't seem to relate to the traffic. What am I doing wrong?
Jules.
bjw
Level 4
Level 4
Try this reference about passive monitoring of TCP connections using the Cisco TCP intercept function.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fsecur_c/ftrafwl/scfdenl.htm
Other than that there are a few show tcp xxx commands that give some summaries related to tcp connections to/from the router itself.
dominic.caron
Level 5
Level 5
Enable netflow on the router(ip route cache flow on interface), you will be able to get stats like this
sh ip cache flow
Total flow/s
TCP-Telnet 4058396 3.2
TCP-FTP 4871555 3.9
TCP-FTPD 308255 0.2
TCP-WWW 442894669 357.8
TCP-SMTP 35046690 28.3
TCP-X 560729 0.4
TCP-BGP 18331 0.0
TCP-NNTP 519092 0.4
TCP-Frag 28724 0.0
TCP-other 698655766 564.4
If you are using a L3 switch, it's a bit harder.
