numbered ACL's
dan.tesch
Level 3
Level 3
I have been working with named (I believe they are called "extended acls"??) for the past few years - I just began working on a router that is using numbered acls - I thought numbered acls did not offer the flexibility to edit them line by liine, I seem to remember having to remove the acl and reapply it? Is this true or is my memory faulty?
2801 router / IOS 12.4
szahid
Level 8
Level 8
Dan :
Numbered ACLs can be edited just like named ACLs .
here is an example from a 2801 router.
D-R2801-13A(config)#ip access-list extended 100
D-R2801-13A(config-ext-nacl)#?
Ext Access List configuration commands:
<1-2147483647> Sequence Number
default Set a command to its defaults
deny Specify packets to reject
dynamic Specify a DYNAMIC list of PERMITs or DENYs
evaluate Evaluate an access list
exit Exit from access-list configuration mode
no Negate a command or set its defaults
permit Specify packets to forward
remark Access list entry comment
thanks
Salman .
Thanks, in the past were there limitations with numbered acls? why would someone use one or the other or simply preference?
Hi Dan,
Yes formerly numbered ACL couldn't be edited, but in the recent codes, you can edit a numbered ACL the same as named ACL, using this or that is simply preference like you've said.
HTH,
Mohammed Mahmoud.
