BGP issue
mohammedrafiq
Level 6
Level 6
I have 3 routers A,B,C connectied in Triangle ,ebgp running between A->C and A->B.Router A on top have BGP peer with AS 34846(ISP 1) and B,C have bgp peer with AS 3356(ISP2) ,All user are connected through router B and C.
I made the chage below on router B to preffer AS 34846 towards ISP1 for prefix 43.252 4.0/22, but it still Preferring path AS 3356 ISP2. All 3 routers gets 0/0 route from my both ISP. Please advise.
RouterB#
router bgp 10753
no synchronization
bgp log-neighbor-changes
network 43.252.0.0 mask 255.255.252.0
network 43.252.4.0 mask 255.255.252.0
network 43.252.156.0 mask 255.255.252.0
neighbor 43.252.0.6 remote-as 34846
neighbor 95.50.116.53 remote-as 3356
neighbor 43.252.0.6 route-map LP in
neighbor 95.50.116.53 route-map AS out
maximum-paths 3
default-metric 100
no auto-summary
ip access-list standard LP
permit 43.252.4.0 0.0.3.255
route-map AS permit 10
match ip address LP
set as-path prepend 10753 10753 10753 10753
route-map AS permit 20
route-map LP permit 10
match ip address LP
set local-preference 200
route-map LP permit 20
W8-7200-CC-1#sh ip bgp
BGP table version is 140628,
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
* 0.0.0.0 43.252.0.6 0 34846 4589 i
*> 95.50.16.53 0 3356 i
* 43.252.4.0/22 43.252.0.6 25625856 200 0 34846 i
*> 0.0.0.0 100 32768 i
*> 43.252.12.0/24 43.252.0.6 0 0 34846 i
*> 43.252.152.0/22 43.252.1.250 100 32768 i
* 43.252.156.0/22 43.252.0.6 25625856 200 0 34846 i
robert.ward
Level 2
Level 2
I am slightly confused by what you are doing.
Is in your routing table from a peer yet you have the network statement in your BGP which you would not do if you were accepting a prefix from a peer.
Are you advertising the prefix to the peers or accepting it.
also are you running iBGP as LP only works within an AS and if your redistributing BGP into an IGP or anything similar then LP wont have any use. I see no iBGP config in your BGP config.
On router B, I am advertising 43.252.4.0/22.
yes there is no IBGP between A,B and C because on B and c my AS is 10753 and on router A we have new AS 34846, so I peer A with B and C by ebgp. so now I want this prefix to in/out through ISP1 which has ebgp peering on rputer A.
I hpoe its clear up.
