%NVRAM: Unable to read configuration. Try again later
Dear Folkz,
I'm getting the below error in cisco 3750 stack switches (8 switches are stacked).
plz advice me that how to avoid this ?? PLz share if any cisco document is available.
InayathUlla Sharieff
Muru,
The issue is triggered when you have a large configuration file and immediately after exiting the configuration mode you attempt to save the configuration in NVRAM.  The issue is related to an internal timer event whose behavior cannot be modified.
If you give a sufficient time between an exit from configuration mode before saving the configuration the problem will not resurface.
You can also find one known DDTS - CSCtn46265 which explains the issue. Please let me know if you have any questions.
Inayath
*Plz rate if this info is helpfull.
Prasan Venky
Level 3
Level 3
you can try erasing the nvram and check
KVS
Even write erase also tried but no luck & problem is still persist :-(
Muru,
Inayath
