NX-OS Upgrade
zekebashi
Level 4
Level 4
I am planning on using ISSU 7.2(0) to upgrade the NX-OS from version 6.2(12) to 7.2(0). Based on this doc: http://www.cisco.com/c/en/us/td/docs/switches/datacenter/sw/7_x/nx-os/release/notes/7x_nx-os_release_note.html#pgfId-1284672; using ISSU 7.2.(0) is compatible with 6.2(12).
However, when I ran the  sh install all impact system bootflash:n7000-s2-dk9.7.2.0.D1.1.bin command and the output states that the two SUPs aren't compatible with the 7.2(0)D1(0) version. The current OS on the chassis is
BIOS: version 2.12.0
kickstart: version 6.2(12)
system:    version 6.2(12)
NX7K# sh install all impact system bootflash:n7000-s2-dk9.7.2.0.D1.1.bin
Installer will perform impact only check. Please wait.
Verifying image bootflash:/n7000-s2-kickstart.6.2.12.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin for boot variable "system".
Performing module support checks.
Verifying image type.
Extracting "system" version from image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin.
Extracting "kickstart" version from image bootflash:/n7000-s2-kickstart.6.2.12.bin.
Extracting "bios" version from image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin.
Extracting "lc1n7k" version from image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin.
Extracting "fexth" version from image bootflash:/n7000-s2-dk9.7.2.0.D1.1.bin.
Notifying services about system upgrade.
Compatibility check is done:
Module bootable Impact Install-type Reason
1 no n/a n/a Incompatible image
2 no n/a n/a Incompatible image
3 yes non-disruptive rolling
4 yes non-disruptive rolling
5 yes non-disruptive rolling
6 yes non-disruptive rolling
7 yes non-disruptive rolling
8 yes non-disruptive rolling
101 yes non-disruptive rolling
102 yes non-disruptive rolling
103 yes non-disruptive rolling
104 yes non-disruptive rolling
105 yes non-disruptive rolling
106 yes non-disruptive rolling
107 yes non-disruptive rolling
108 yes non-disruptive rolling
111 yes non-disruptive rolling
112 yes non-disruptive rolling
113 yes non-disruptive rolling
114 yes non-disruptive rolling
115 yes non-disruptive rolling
116 yes non-disruptive rolling
117 yes non-disruptive rolling
118 yes non-disruptive rolling
Not all components in the image are compatible.
ISSU can't continue
What does this mean? Does this mean ISSU 7.2 will fail to upgrade the two SUPs?
~zK
InayathUlla Sharieff
Can I have the following output:
show module?
show module?
zekebashi
Level 4
Level 4
I was able to find a solution. The reason why I received that error message was because the command listed on the release notes was incorrect.
The release notes states to use this command:
However, this is the correct command:
sh install all impact kickstart bootflash:n7000-s2-kickstart.7.2.0.D1.1.bin system bootflash:n7000-s2-dk9.7.2.0.D1.1.bin
Thanks for your attempt to help. Much appreciated.
Best, ~zK
Nearly two years later and the documentation is still not very clear. There is a carriage return in the documentation which leads to an incomplete command .  This tip solved my problem.
Agree, the documentation isn't the most helpful. The command "install all" is great, if there are no other files in flash. If you actually want to select a specific file you can use the following
"install all kickstart bootflash:nXXXX-sx-kickstart.X.X.XX.bin system bootflash:nXXXX-sX-dk9.X.X.XX.bin
