NX-OS VPC topology
networkinggeek
I am new to nexus and trying to learn some practical applications of NX-OS. I have this lab built, I added two nexus switches so I can learn the concept of VPC. Now I need to connect my PC1 to PC2 so that they can ping each other going through vpc. If I create vpc on both sides it becomes layer 2 connection, how to complete this diagram (in blue circle) using vpc and get connectivity across between PCs?. Do I need to enable L3/igp protocols on nexus as well?
18 Replies 18
Have you tried with newer NX-OS version?
Also there's a know bug issue with LACP and NX-OS 7. The fix is:
https://techstat.net/cisco-nexus-nx-osv-9000-lacp-vpc-bug-fix/
Can you try please and let us know?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
Super! that exactly was the issue, I followed the instructions to resolve the bug. Thanks @francesco for helping me out on this one. I have marked your first response as the correct answer. Thanks again :)
Thanks you're welcome.
I forgot about this big and when I've tried it with same version i remembered and done a quick research!
Glad that worked!
Francesco
networkinggeek
See above outputs, let me know if anything more is needed!
