object-group base ACLs removed after reboot the cisco 4500x switch
Srinivas N
Hi Team,
Earlier we have created combination of object group acl & normal acl on cisco 4500x switch (HA).
yesterday, due to power issue suddenly our switch has been rebooted and we have noticed that when switch is up, object-based ACLs were removed, but object entries are not removed.
Below are the sample ACLs and switch version details, can anyone address the reason.
Switch details
WS-C4500X-32
Version 03.08.01.E RELEASE SOFTWARE (fc2)
cat4500e-universalk9.SPA.03.08.01.E.152-4.E1.bin
object group ACLs (after switch rebooting, those were remove)
30 permit object-group HYD_CommonSer-Ports 10.100.18.0 0.0.0.127 object-group HYD_Common-Servers
40 permit object-group HYD_ConfNW-Ports 10.100.18.0 0.0.0.127 object-group HYD_ConferenceNW
50 permit object-group HYD_EMail-Ports host 192.168.108.5 host 192.168.2.222
60 permit ip 10.100.18.0 0.0.0.127 object-group HYD_Common-Servers
61 permit object-group TEMP-PORTS 10.100.18.0 0.0.0.127 object-group TEMP-SERVERS
Normal ACLs (after rebooting the switch, no impact)
access-list 2006 permit tcp host 192.168.32.231 host 192.168.19.200 eq 22
access-list 2006 permit tcp host 192.168.32.235 host 192.168.19.200 eq ftp
access-list 2006 permit tcp host 192.168.32.235 host 192.168.19.200 eq 22
access-list 2110 permit tcp host 192.168.52.32 host 192.168.19.200 eq 443
access-list 2110 permit tcp host 192.168.52.55 host 192.168.19.200 eq 443
access-list 2110 permit ip host 192.168.52.103 host 192.168.19.200
access-list 2110 permit tcp host 192.168.52.19 host 192.168.19.200 eq www
Thanks & Regards,
Srinivas.
balaji.bandi
Are you sure the config is saved ? what happends when you add the config back ? is that taking or not taking ?
BB
SW# show diagnostic result module 1 detail <- do this check the memory if it pass check or not.
Hi MHM Thanks for reply.
below is the status of diagnostic.
4) supervisor-rx-errors ------------> .
Error code ------------------> 0 (DIAG_SUCCESS)
Total run count -------------> 15913
Last test testing type ------> Health Monitoring
Last test execution time ----> Apr 21 2022 16:02:03
First test failure time -----> n/a
Last test failure time ------> n/a
Last test pass time ---------> Apr 21 2022 16:02:03
Total failure count ---------> 0
Consecutive failure count ---> 0
we will save the config frequently.
Since power issue device was rebooted, only group-based ACLs were removed, normal ACLs and other configuration are fine.
Thanks & Regards,
Srinivas.
rubenmartinez2
Was a solution ever found? I am having the same issue without any luck.
