object-groups for acls strange behaviour
falain
on ISR 12.4(20)T2, object-group for acls feature have a strange behaviour
object-group service OGs_Standard
eigrp
icmp
tcp eq echo
IP access-list extended Acl_Inside
210 permit object-group OGs_Standard any any
220 deny ip any any log (22 matches)
1) at boot time, it works correctly
2) after some time or some changes in config, it stops allowing eigrp or icmp.
Then cutting off routing updates or ping packets:
Apr 14 14:50:01.830 CET: %SEC-6-IPACCESSLOGDP: list Acl_Inside denied icmp x.x.x.x-> y.y.y.y (8/0), 5 packets
Apr 14 14:50:01.830 CET: %SEC-6-IPACCESSLOGDP: list Acl_Inside denied icmp x.x.x.x-> y.y.y.y (8/0), 4 packets
Apr 14 14:50:01.830 CET: %SEC-6-IPACCESSLOGDP: list Acl_Inside denied icmp x.x.x.x-> y.y.y.y (8/0), 7 packets
3) if I add equivalent classical ACE rights, then I can ping again:
220 permit eigrp any any
230 permit icmp any any (7 matches)
240 permit tcp any any eq echo
250 deny ip any any log
4) a user reported me that ssh was allowed from one DMZ server to another (inside) one
Nothing on server's Acl was visible that could explain.
I then added an ACE in the middle of the Acl to deny such a traffic (tcp/22)
Then, ssh trafic was refused (Linux server reported 'no route to host')
I then suppressed the new ACE in order to move it elsewhere downwards in the Acl (thinking permitting rule was after)
But before adding ACE, I tried ssh connection again:
ssh trafic was refused again !
How would I be confident in my security rules ?
joneschw1
Did you get a resolution to this issue. I am experiencing the exact same problem with the nested object group.
mrmoothe
There have been a few instances of buggy behavior involving object groups.
Let me dig up and see what I find.
I'll update this thread if I find something.
