voice vlan on switch
raulzulueta
I have a 3750 PoE switch with vlan 10 for data and vlan 50 for voice. I am having problems when i move the phone and pc to a new port. It does not get on the network unless I flip the switchport trunk native vlan between vlan 10 and vlan 50. Can you check the switch config I attached to determine if I need to change anything? I am testing with fa 1/0/28 port.
Thanks.
Souvik Ghosh
We need to know what is the IP phone you are using. If you are using a Cisco IP phone then the commands which you need are.
interface FastEthernet1/0/28
switchport access vlan 10
  switchport voice vlan 50
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape  10  0  0  0
mls qos trust cos
auto qos voip trust
Voice vlan command is only supported with Cisco IP phone.
For a non-cisco IP phone the configuration would be.
switchport trunk native vlan 10
switchport trunk allowed vlan 10,50
switchport mode trunk
mls qos trust cos
auto qos voip trust
spanning-tree portfast
Could you please remoeve the redundant configuration and check the behavior. Also if you are using non-cisoc IP phone then you have to configure the phone in vlan 50 ( i guess that has already been done ).
Rgds,
Souvik
