%OCE-3-MISSING_HANDLER_FOR_SW_OBJ_TYPE
erodriguez27
Community Member
                   Hi, i have a 3750 ME
(C3750ME-I5-M), Version 12.2(37)SE1, RELEASE SOFTWARE (fc1)
The cpu processes is in 90% and 80%
CORE-MPLS-3750ME-1-HOWA#sh processes cpu | exclude 0.00
CPU utilization for five seconds: 61%/43%; one minute: 58%; five minutes: 57%
PID Runtime(ms)   Invoked      uSecs   5Sec   1Min   5Min TTY Process
  21      689503   2444665        282  0.15%  0.10%  0.08%   0 ARP Input
  46    11653085   6383250       1825  0.15%  0.16%  0.15%   0 Adjust Regions
  47     3936737   5563541        707  0.15%  0.04%  0.04%   0 FE free chunk
  58    15005707 472794278         31  7.50%  7.58%  7.04%   0 HLFM address lea
107    17564793 379398332         46  0.15%  0.15%  0.20%   0 Hulc LED Process
108    99065861  11691358       8473  0.63%  0.79%  0.81%   0 HL3U bkgrd proce
135    14193067  79281289        179  0.15%  0.12%  0.15%   0 IP Input
138      761090  15891677         47  0.31%  0.12%  0.09%   0 PI MATM Aging Pr
238    61771997   3185113      19394  0.47%  0.52%  0.50%   0 MFI LFD Stats Pr
242     7227189  19760005        365  1.91%  0.26%  0.13%   0 ISIS Upd
290         109        85       1282  0.95%  0.12%  0.02%   1 Virtual Exec
Apr 15 13:31:03: %OCE-3-MISSING_HANDLER_FOR_SW_OBJ_TYPE: Missing handler for 'non choice oce get next' function for type Midchain
Apr 15 13:33:29: %OCE-3-MISSING_HANDLER_FOR_SW_OBJ_TYPE: Missing handler for 'non choice oce get next' function for type Midchain
Apr 15 13:44:18: %OCE-3-MISSING_HANDLER_FOR_SW_OBJ_TYPE: Missing handler for 'non choice oce get next' function for type Midchain
I try to find the origin of the problem
The 3750 have the nex log's
This because the version have a bug (bug CSCsi51035), can the bug afect the processor?
InayathUlla Sharieff
Hi Ero,
The %OCE-3-MISSING_HANDLER_FOR_SW_OBJ_TYPE:
<http://www.cisco.com/cgi-bin/Support/Errordecoder/index.cgi?action=sear
ch&counter=0&paging=5&links=reference&index=all&query=OCE-3-MISSING_HAND
LER_FOR_SW_OBJ_TYPE>  messages you are receiving is actually a common
bug which has been running in the 3750 IOS train for quite some time.
The messages you are seeing are informational only (no operational
impact - except that it floods the log buffer which is the reason you
cannot tell when it started).
This is actually an IOS 'cosmetic' bug, and can be seen in further
detail on the following link:
http://wwwin-metrics.cisco.com/cgi-bin/ddtsdisp.cgi?id=CSCsi51035
Workaround:
There is currently no workaround for the issue.  However, the issue is
fixed in the latest IOS image release 12.2(40)se, which is available on
CCO and you can upgrade to get it resolved.  Please note however, that
the issue you are experiencing is only informational, and will not
impact the operational performance of the switch in any way.
REgards
Inayath
        *Plz rate if this information is helpfull.
