Odd 2507 Console port problem, need ideas
jburton72
I recently purchased an old 2507 off ebay while I work on CCNP. It was dirt cheap and came configured with who-knows-what. The problem is I have a rj45-db9 rollover cable that I use to connect to and configure my 2514's and it works fine. On the 2507 however, I cannot see anything from the console port. I can still issue commands though which is wierd. I know I can issue commands because I was able to plug into the aux port and observe my changes. It not a huge problem because now I have an IP on the ethernet interface so I can telnet all I want, but I was wondering if anyone could tell me why I can issue command through the console, but I never see any characters back at all...nothing nada zilch...and I know the console cable is good because it works on my 2514's. Any help would be wondeful.
ethiel
Level 3
Level 3
Do you have any unusual config on the console port? Or is it possible there is a bent pin?
-Eric
Please remember to rate all helpful posts.
no unusual config that im aware of. The only odd things i see on the line con is "transport input none". I turn it off but it comes back every time i reboot the router even after saving the config.
glen.grant
probably the config register is incorrect , usually should be set at 0x2102 . You should be able to see what it with a show version command i believe .
