04-05-2013 06:08 AM - edited 03-07-2019 12:39 PM
Hi. We installed an MPLS network this week an while there is connectivity and propagation of routers between all nodes
we have the ISP router (172.18.1.17) plugged into a catalyst 3750X (vlan 102 ip address 172.18.1.18)
Also plugged into the catalyst is another catalyst via trunk. 172.18.1.19
The user vlan that we have published via ospf is 192.168.0.0/24.
If I do a traceroute to a workstation on the first switch it shows mpls router -->second switch --> workstation on the first switch.
If I do a traceroute to a worksation on the second switch it shows mpls router --> second switch --> timeout...
Can someone tell me why:
A) the second last hop is the ip of the switch that ISNT plugged direclty into the MPLS router
B)if A is normal why I cannot reach workstations on the second switch.
Here are the (abbreviated traces) .51 is a WS on the second switch. .18 is a WS on the first switch. Within the vlan there is full connectivity.
Tracing route to 192.168.0.51 over a maximum of 30 hops
1 2 ms 1 ms 1 ms 172.16.1.1
2 2 ms 1 ms 1 ms 172.18.1.1
3 1 ms <1 ms <1 ms 172.30.34.1
7 10 ms <1 ms <1 ms 172.30.34.9
8 10 ms 9 ms 9 ms 172.30.34.10
9 10 ms 10 ms 44 ms 172.18.1.19
10 * * ^C
C:\Users\andrewc>tracert -d 192.168.0.18
Tracing route to 192.168.0.18 over a maximum of 30 hops
1 3 ms <1 ms 1 ms 172.16.1.1
2 1 ms 1 ms 1 ms 172.18.1.1
3 <1 ms <1 ms <1 ms 172.30.34.1
7 <1 ms <1 ms <1 ms 172.30.34.9
8 10 ms 10 ms 10 ms 172.30.34.10
9 13 ms 9 ms 10 ms 172.18.1.19
10 12 ms 13 ms 23 ms 192.168.0.18
04-16-2013 12:23 PM
Hello Andrew,
Do you have correctly configured default-gateway/routing on second switch [depends on if it is L2/L3 switch]?
Can you post configuration of both switches?
Best Regards
Please rate all helpful posts and close solved questions
