04-16-2013 03:14 AM - edited 03-07-2019 12:50 PM
Hi Guys,
We are looking to upgrade the version of IOS on the 6500s this evening and in preparation i've dowloaded the image to sup-bootdisk. However when trying to update the boot path as follows I see the following error:
Version we are updating is:
s72033-ipservicesk9-mz.122-33.SXJ4.bin
Directory of sup-bootdisk:/
4 -rw- 86602532 Apr 16 2013 11:44:12 +02:00 s72033-ipservicesk9-mz.122-33.SXJ4.bin
1 -rw- 33554432 Jan 20 2010 09:26:30 +02:00 sea_console.dat
2 -rw- 33554432 Jan 20 2010 13:33:36 +02:00 sea_log.dat
3 -rw- 98539332 Feb 16 2010 18:26:40 +02:00 s72033-ipservicesk9_wan-mz.122-33.SXI3.bin
1024557056 bytes total (772292608 bytes free)
musa-core-sw2#wr
Building configuration...
[OK]
musa-core-sw2#conf t
Enter configuration commands, one per line. End with CNTL/Z.
musa-core-sw2(config)#boot system flash sup-bootdisk:s72033-ipservicesk9-mz.12$
% ISSU process is in progress; Boot variable can not be updated.
Why are we seeing this message when the router is not doing anything with ISSU??
Any assistance would be much appreciated.
thanks
Sheldon
Solved! Go to Solution.
04-16-2013 10:43 AM
can you try?
clear issu state
and then try the boot statement again.
04-16-2013 10:43 AM
can you try?
clear issu state
04-16-2013 11:01 AM
Hi Reza,
thanks very much - that did the trick! Any idea why the router would have been stuck in that state?
thanks
Sheldon
04-16-2013 11:21 AM
Hi Sheldon,
I don't remember exactly what causes it, but I know, I have seen that error before.
It may also be a bug in the code.
Reza
