01-22-2011 11:47 AM - edited 03-06-2019 03:08 PM
I've configured my router as you can see in attahement (the same router is master and border). X.X.X.X is my router's Lo0 ip address, A.B.C.D/24 is my configured prefix and A.B.C.E is a host in A.B.C.D/24 network.
I'd like to see my configured active probe when I type the command 'show oer master active-probes'. But the list is empty. Could you tell me why?
02-23-2011 07:56 PM
Did you have active traffic traversing your Border Routers when you issued show oer master active-probes? The BRs need to learn of traffic before probes will be created.
Let me know if you have further questions.
Best Regards,
Steve Lyons - Cisco
02-28-2011 09:32 AM
Hello Steve,
No, I haven't actual traffic. If I understand you correctly, I can't see my configured active probes in the output of 'show oer master active-probes' before traffic is transmitted. Is it true?
02-28-2011 11:10 AM
You will need traffic to see the probes. I would also recommend actual TCP and UDP traffic. Once you have traffic then you can issue "show oer master active-probes force - which details manually configured probes, and "show oer master traffic active-probes application - which details automatically created probes.
Best Regards,
Steve Lyons - Cisco
