OID INTERFACE RATE
Silvio Rodrigues
Community Member
Dears I need to know what IOD is to:
  5 minute input rate 149000 bits/sec, 46 packets/sec
  5 minute output rate 58000 bits/sec, 29 packets/sec
I need OID to get this value:
149000 and 58000
Rolf Fischer
Level 11
Level 11
Silvio,
you can't query this values directly, instead you'll have to query the Interface-MIB OIDs ifInOctets and ifOutOctets in (5 minute) intervals, calculate the difference (that's the way tools like MRTG and Cacti work), and convert it to bps.
interfaces.ifTable.ifEntry.ifInOctets.10101 = Counter32: 3793307761
interfaces.ifTable.ifEntry.ifInOctets.10101 = Counter32: 3793335655
=> 27.894 byte in 10 sec = 22,3 kbps
Note: This are 32-bit counters. When the maximum value is reached (~4.2 billion), the counter re-starts with Zero. So if the second value is less than the first, you have to consider this in your calculation.
Hope that helps
Rolf
