OM3 Fiber cable between two switches??!!
jolo07310
Level 5
Level 5
Hi all,
We have OM3 fibers panel (support 10GE) between 1st and 2nd fl. Total 3 connections.
We have 4510R with TWO SupV-10GE (Dual Sup) at the 1st FL. and 4506 Sup II Plus 10GE at the 2nd FL.
I connect 10GE with trunk without any problem.
However, I try to use two of SFP (Total 4) to trunk in case 10GE down, and it doesnt work. I tried to use OM3 patch cable (SC-LC) or OM2 patch cable (SC-LC), but no luck.
Does anyone know why? Does OM3 support backward compatible to 1.0GE??
Thanks for help.
Ken
owillins
Level 6
Level 6
OM-3 fibers are a new category of 50 ?m multimode fibers optimized for 850 nm (like 10GBASE-S) 10GbE operations up to 300 m.
OM-3 fiber is a flavor of 50 ?m multimode fiber and has a modal bandwidth of 2000 MHz*km.
OM-3 fibers are not part of the original Gigabit Ethernet standard for 1000BASE-SX and 1000BASE-LX, but are introduced in the 10 GbE standard.
