on 2960-24TC-L uplink(SFP) not up after updrade
fernandezj
I have a switch 2960-24TC-L with GEC (realised with 2 giga interface uplink) with switch 3750.
the configuration is ok, the GEC is up and other feature working.
I try to upgrade 2960-24TC-L from 12.2.44SE6 to 12.2.46 or 12.2.5x or 15.0.x...the upgrade it's ok the swithc boot..and the configuraiton is same...
but the giga 0/1 and 0/2 on 2960 not bring up....and the better the interface on 3750 are up.....
If you have idea???
best regards
Reza Sharifi
Under interface gi0/1 and 0/2 did you do a "no sh"?
Can you post "sh int gi0/1 capa"?
What is the interface on the 3750 side?
Can you post configs?
Hi Reza,
yes i do shut no shut and reboot..with no result....
The interface configuration on 2960:
interface Port-channel1
description GEC vers WAN
switchport mode trunk
duplex full
storm-control broadcast level 1.00
storm-control multicast level 1.00
interface GigabitEthernet0/1
description GEC BB
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust cos
storm-control action trap
auto qos voip trust
channel-group 1 mode on
interface GigabitEthernet0/2
description GEC BB
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
and show interface capa
GigabitEthernet0/1
  Model:                 WS-C2960-24TC-L
  Type:                  1000BaseSX SFP
  Speed:                 1000
  Duplex:                full
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100)
  Flowcontrol:           rx-(off,on,desired),tx-(none)
  Fast Start:            yes
  QoS scheduling:        rx-(not configurable on per port basis),
                         tx-(4q3t) (3t: Two configurable values and one fixed.)
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  SPAN:                  source/destination
  PortSecure:            yes
  Dot1x:                 yes
  Multiple Media Types:  rj45, sfp, auto-select
GigabitEthernet0/2
  Speed:                 1000
  Duplex:                full
  Channel:               yes
  Fast Start:            yes
  CoS rewrite:           yes
  ToS rewrite:           yes
  UDLD:                  yes
  Inline power:          no
  PortSecure:            yes
  Dot1x:                 yes
Port-channel1
  Model:                 not applicable
  Speed:                 1000
  Duplex:                full
  Channel:               no
  Fast Start:            yes
  QoS scheduling:        no
  CoS rewrite:           no
  ToS rewrite:           no
  UDLD:                  no
  Inline power:          no
  SPAN:                  source
  PortSecure:            no
  Dot1x:                 no
and on switch 3750:
interface GigabitEthernet1/0/12
description GEC WAN
speed nonegotiate
srr-queue bandwidth share 1 30 35 5
srr-queue bandwidth shape 10 0 0 0
priority-queue out
mls qos trust cos
auto qos trust
rmon collection history 10112 owner campusmanager buckets 10 interval 300
channel-group 6 mode on
best regards
Zubair.Sayed_2
Have you tried adding the following commnd to the port channel interface:
Some interface also require you to hard code speed and duplex, you can try these commands also.
You might also want to try removing all the other config from the interfaces and just keep the basic config to see if the interfaces and port channel comes up.
interface GigabitEthernet0/23
description xxxxxx
end
interface GigabitEthernet0/24
description xxxxxxxxx
end
interfaceface Port-channel1
end
Thereafter issue a 'show int status' to see if there are any error conditions for those interfaces like err-disable.
Zubair
