How to configure VSS with two different supervisor engine (3c & 3cXL) in 6500 series
maniselvam77
Dear all,
          I have configured the VSS in two cisco 6509-E series with only one supervisor engine, but if i configured with two supervisor engine. it is going to rommon mode. One supervisor engine is 3c and 3cxl. Please advice.
Hello Selvam,
Both the supervisor modules has to be same in order for them to operate in VSS mode
Please refer the below document
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1053954
Harish
Please rate helpful posts!
Hello Selvam,
Harish
Hi Harish,
              I have one 65000 series with two VS-S720-10G-3C and another VS-S720-10G-3CXL, It will support or not, I have configure with one supervisor engine each. It is working fine. I have configured with VS-S720-10G-3CXL
Selvam
