On Cisco 3850 is the 1Gbps/10Gbps uplink module hot pluggable?
CiscoMedMed
I'd like to move the uplink module seen below from on 3850 to another. Can I remove it
while the 3850 is operating (or insert it while the other is operating)?
NAME: "Switch 1 FRU Uplink Module 0", DESCR: "2x1G 2x10G Uplink Module"
PID: C3850-NM-2-10G , VID: V01 , SN: FOC20357XHK
balaji.bandi
The network module is hot-swappable. If you remove a module, replace it with another network module or a blank module.
Personally, I will advise do it in a maintenance window.
read the guide lines :
https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3850/hardware/installation/guide/b_c3850_hig/b_c3850_hig_chapter_011.html#topic_6C2E7F93C4D4472ABF9766C84E75636C
BB
balaji.bandi
BB
CiscoMedMed
Thank you!
