One of the VSL links in suspended mode after 'force switch-over'
Ji-Won Park
Hello all,
I keep getting the below alert while i'm running failover testing scenarios. Please let me know if there's anything missing or anyone experienced same issue before.. After I issue 'redundancy force-switchover' the fail-over happens but one of the VSL links is put in suspended mode.
*Sep 15 19:21:15.283: %EC-SW2-5-CANNOT_BUNDLE2: Te1/5/4 is not compatible with Te1/6/4 and will be suspended (Operational flow control receive of Te1/5/4 is on, Te1/6/4 is disagree)
*Sep 15 19:21:15.667: %EC-SW2-5-CANNOT_BUNDLE2: Te2/5/4 is not compatible with Te2/6/4 and will be suspended (Operational flow control receive of Te2/5/4 is disagree, Te2/6/4 is on)
1      Po1(RU)          -        Te1/5/4(s)     Te1/6/4(P)
2      Po2(RU)          -        Te2/5/4(w)     Te2/6/4(P)
##Setup
6506E-SUP2T VSS
IOS - 15.1(1)SY1
Te1/5/4, Te1/6/4 - Te2/5/4, Te2/6/4 are 2 x 10Gb VSL (Copper)
Gi1/2/48 is the heartbeat (Copper)
##Configuration
interface TenGigabitEthernet1/5/4
description VSL
no switchport
no ip address
no cdp enable
channel-group 1 mode on
end
interface TenGigabitEthernet1/6/4
description VSL
no switchport
no ip address
no cdp enable
end
interface TenGigabitEthernet2/5/4
description VSL
no switchport
no ip address
no cdp enable
channel-group 2 mode on
end
interface TenGigabitEthernet2/6/4
description VSL
no switchport
no ip address
no cdp enable
end
switch virtual domain 1
switch mode virtual
switch 1 priority 110
mac-address use-virtual
interface GigabitEthernet1/2/48
description VSL HEARTBEAT
no switchport
no ip address
no cdp enable
dual-active fast-hello
end
interface GigabitEthernet2/2/48
no switchport
no ip address
no cdp enable
end
Thanks in advance.
J
Reza Sharifi
You configuration is correct.  You also have an issue with Te2/5/4(w) (waiting to be bundled).
Can you test by putting both 10Gig ports on the same Sup?
it would be 1/5/4 and 1/5/5 for each chassis.
Hi Reza,
Te2/5/4 (w) is connected to Te1/5/4 (s). I will try to use 1/5/4,1/5/5 for VSL and post the output soon. I feel like i'm hitting a bug...
J
Hey Reza,
VSL Links seem to be okay when I'm using Te1/5/4&Te1/5/5 <-> Te2/5/4&Te2/5/5.
But using Te1/5/4&Te1/6/4 will give me more redundancy. Is there any reason why the port bundling fails when using two different SUP interfaces?
J
