different between ISO. NATIVE IOS , catOS
fb_webuser
Level 6
Level 6
waht is the different between ISO. NATIVE IOS , catOS
which switch and router support OS.
Please specify with model mane
Posted by WebUser Romeo Zahedul Hoque from Cisco Support Community App
All Cisco Catalyst switches currently manufactured run IOS. CatOS has not been shipping on any Catalyst switch since about 2008. The CatOS End-of-sale and End-of-Life notice announces this:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps708/prod_end-of-life_notice0900aecd80699e1a.html
If you have a very old switch that is still running CatOS, in most cases you cannot replace its operating system with IOS. There are some exceptions (i.e., the Catalyst 6509) but any switch that old is well past its useful lifetime and would be better replaced with a modern one running IOS.
Cisco routers have always run IOS since it was branded as such back in the early 1990s. Some newer Catalyst switches and routers run a variation known as IOS-XE and some ASR routers (plus the CSR and 12000) run IOS-XR. They are still "IOS" but have some modular features and are built on a Linux kernel (IOS-XE) or QNX Realtime Operating system (IOS-XR).
Nexus switches run NX-OS.
Lots of information including the model numbers you asked about are on this Cisco white paper:
http://www.cisco.com/web/about/security/intelligence/ios-ref.html
Reza Sharifi
IOS and Native IOS are the same thing. As for cat OS, that is about 10 years old and use to run on catalyst 6500 switches.  It is also EOL and support.  All switches now days run IOS.
Disclaimer
The   Author of this posting offers the information contained within this   posting without consideration and with the reader's understanding that   there's no implied or expressed suitability or fitness for any purpose.   Information provided is for informational purposes only and should not   be construed as rendering professional advice of any kind. Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In   no event shall Author be liable for any damages whatsoever (including,   without limitation, damages for loss of use, data or profit) arising  out  of the use or inability to use the posting's information even if  Author  has been advised of the possibility of such damage.
Posting
Not precisely.
Years ago, chassis switches like the 5500 or 6500 series ran both Cat OS and IOS on them.  Cat OS on the L2 supervisor and IOS on the L3 RSM.  Cisco released a version of IOS that, at least for the 6500s, supported the L2 supervisor natively, i.e. Cat OS was no longer needed.  Such an IOS was known as Native IOS.  Running both Cat OS and IOS was known as running in hybrid mode.  When both IOSs were available, you might stay with the hybrid combination as there was not 100% parity in features.
PS:
And for a bit of trivia, for the 5500s, you could also run the switch without a RSM, but working in conjunction with an external router, the later supporting MLS on the 5500.
fb_webuser
Level 6
Level 6
IS any modern switches by default run CatOS, Voip switch Run which OS[ catos or IOS?] can i migrate from CatOS to IOS?
