OpenFlow on Cisco Catalyst 9200
hobian
I am currently working on the Openflow configuration on Catalyst 9200 switches. Basically, I am following the link: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/prog/configuration/1611/b_1611_programmability_cg/OpenFlow.html
to set up the switch to work with Openflow. However, I can only successfully proceed until changing the boot mode to openflow. When I try to move on, the switch does not have "feature openflow" command to enable the openflow feature.
Does anyone know why this is happening?
Thanks!
Gustav92
Greetings. Sadly, openflow is currently not supported on the catalyst 9200 series. It has been implemented in 9300, 9400 and 9500 series, but at the time of this answer, it is still unsupported on the catalyst 9200. Refer to this link:
