Operation of Virtual Stacking on 9500
xslll
Hello guys,
I want to know how switches that are stacked virtually would operate. Would you require separate management IP’s for them, are the configurations synch across. Also, can I run the stack-wise config on interfaces that are bundled together using ether channel?
balaji.bandi
You can connect both MGMT port to out of band switch, But only Active Switch will be active, the standby one will not be reachable.
when the action failed, standby will pick up that management IP and be reachable.
check below guide :
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9000/nb-06-cat-9k-stack-wp-cte-en.html
 can I run the stack-wise config on interfaces that are bundled together using ether channel?  - this is not supported.
BB
I know a little but, management IP make us know we connect to which SW without depend to show master status of stack.
I will make check.
can I know you ask for outband management or inbnad managment ??
