OPTION 150 in two VOICE HDCP POOL IN SAME SWITCH
I am having two sides.  Side A is getting IP address via DHCP Pool (Voice and Data).  Side A SW is direct trunk with Core SW. Side A is working Fine.
Side A configuration is bellow
ip dhcp excluded-address 10.10.10.193
ip dhcp excluded-address 10.10.20.193
ip dhcp pool data
   network 10.10.10.192 255.255.255.192
   default-router 10.10.10.193
ip dhcp pool voice
   network 10.10.20.192 255.255.255.192
   option 150 ip 10.10.30.1
   default-router 10.10.20.193
Interface Vlan10
Description **** For Data VLAN ****
IP address 10.10.10.193 255.255.255.192
Interface VLAN20
Description ****FOR VOICE VLAN *****
Now we are going to Add Side B. We want to add some phone on Side B. Side B SW will be  direct trunk with Core SW.
What should I do? If I create another Voice DHCP pool will it work for option 150.??
I am really Confused….? How to configure it.
rahurao
Hi Sultan,
If you want the second switch to take the ip addresses from the Side A pools, then you just need to configure the ip helper statements on the respective interface vlans pointing towards the side A.
Configuring a Cisco router to forward BootP or  DHCP requests is simple - configure an IP helper-address pointing to the  DHCP/BootP server, or pointing to the subnet broadcast address of the  network the server is on.
You can look at the ip helper configuration from the following configuration link:
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t1/feature/guide/Easyip2.html#wp7038
Rahul
